Gresen hyd valve
Ken Henry
Hi guys, I know this isn't a jd question specifically but I have a Gresen 3 spool hyd. valve 2753. It was on a jd so set up for closed center. I want to make it open center. Does anyone have a manual or schematic or knowledge to help with this project. Thanks for any help.
Ken
some valves are convertible from open center to closed center by using a screw in plug, not sure that all are that way. You might be able to search internet for that valve and find out if you can convert it to open center
Go to JD parts and to 48 loader. That plug used to be available there. If not at least you should be able to see what it looks like.
