I"ve had the tractor split 2 times to fix this leak. Second split went into the PTO and the PTO brake was replaced and PTO is now working correctly.
Second time mechanic said he missed one of the seals near the bell housing?
The PTO valve on the left side of the transmission was re-built with the second split.
Inside the dash/console looks dry.
I get about 1/2 pint of Hydro fluid in a catch pan after shutting it off. Probably 1 or 2 drips per second when hot and running.
Can someone tell me all the places this could be leaking from? Possibly a worn transmission shaft? Leaking past the clutch pack seals?
I"m assuming the pilot bushing was replaced when split.
Any insight would be appreciated. I think for now I"ll just keep adding oil until it gets to the point that I must have it split again. Any problems with this?
I basically use the tractor heavy 4-5 times a year for hay and for pulling a 15" bat wing mower. Something like 7 hours straight mowing.
Thanks.
Thanks.
