Anonymous-0
I am looking at buying an 8630 with jd front blade. Anyone know what that blade is worth. Would it be hard to resell the blade.
I would not advise buying an 8630 with a blade, they see way to much fore and aft shifting,, the sychronizers and shift system will be worn bad,,
Hi
For some reason there are a lot of those 30 series 4wd tractors round us in Manitoba Canada, that have 40 series motors fitted. not sure why, but I'm guessing there could also be a problem with motors. it's not uncommon to see this made a big point,when selling them used round here!
Regards Robert
The primary problem with the 30 series engine was the cam shaft driven oil pump, the later engines have a "crank shaft" driven pump,,much better..
Hi
Thanks for the reply I guess that would be the reason then. It"s a good day when a guy learns something useful.
Regards Robert
Give me a call and I think we can work something out. The blade is over towards you. 231/757/0064 or email me your ##
