Waterloo
I have used a stock "G" in several different conditions. The best performance I got was a 50/50 mix gas and kerosene. Diesel fuel performed ok, however, if the tractor ever pulls down it takes a long time for the RPM"s to come back up. With a change to Alum higher compression pistons and manifold change the "G" is a different tractor I believe 50HP would be conservative.
