Will a 148 loader fit on a 6405 tractor ?
JD720
Will a 148 loader fit on a 2wd 6405 tractor without major modification this loader is off of a 4430 tractor would the frame rails be the same width ? Will the holes line up or will they all have to be redrilled ?
I tried to find some info in JDparts.com to determine an answer to your question but I failed. It would surprise me if mounting brackets will fit your 6405. If 148 loader has a hyd valve it won't operate on your 6405.
