1940 John Deere H
1948bnh
New User
Tractor runs ok,pumps oil out of fitting on governor but shows no pressure on known good gauge off unstyled B. Also oil at valve cover fitting. Where is pressure ajusted?
Below the belt pulley there is a plug you remove to adjust the oil pressure with a long screwdriver. Turn it to the right to increase the pressure. Pressure should be between 10 and 15 psi.
