TractorLinks.com
Show Parts for Model:
Re: 4020 Clutch and PTO release bearing replacement
jsborn
10-11-2013 04:22:18
Thanks for the input. I assume from the comments that the transmission bearing comes off separate from the bearing collar and the collar stays on the shaft?
If that is correct after the bearing is removed do I have to disconnect the operating linkage from the PTO operating Sleeve so it can be removed or will the PTO bearing and collar come out on its own while leaving the operating sleeve on the shaft with some tapping ?
This post was edited by jsborn at 04:23:55 10/11/13.
D-
10-11-2013 15:59:28
 Re: 4020 Clutch and PTO release bearing replacement in reply to jsborn, 10-11-2013 04:22:18
The collar usually comes off the tube, sometimes easy sometimes very tight.
You might have to disconnect the pto operating rod in the bell housing so the fork will allow the carrier to be removed. Occasionally the bearing will come off but usually is pressed. Check collar that engages the pto fingers for wear.
