TractorLinks.com
Show Parts for Model:
Re: Re:
Kent Petersen
10-11-2013 03:10:48
There would not be any data on gas Gs because Deere never made any. gas pistons and manifold came out as parts from deere near the end of G productsion a good G with the gas conv. would put out About 50 to 55 hp
clampdaddy
10-11-2013 08:17:13
 Re: Re: in reply to Kent Petersen, 10-11-2013 03:10:48
Yeah, just curious if anybody ever tried dyno'ing a bone stock G while running it on gas. Once I get the clutch parts for mine to get it mobile I was thinking about pulling it once before I swap out the pistons, just for fun. Just wondering if I should run it on gasoline or if I should buy a couple gallons of kerosene.
mike m
10-11-2013 17:00:28
 Re: Re: in reply to clampdaddy, 10-11-2013 08:17:13
I bet very few stock ones around. Many had the flat head added to boost power.
Mike M
10-11-2013 05:55:22
Those figures are right in line with what I dynoed a late G at that was overhauled and the only modification was to install gas alum. pistons. Nothing wild just so it would still run on cheap pump gas.
And as to the gas verses all-fuel when stock on my 1946 A as I was in the middle of the field plowing I switched from gas to kerosene or vice versa ? and the only differance I could tell was the smell of the exhaust.
And just for curiosity on my 1945 B which was upgraded to .045 over JD cast iron gas pistons I tried kerosene in it. When first switched it seemed to sit there and run fine,but the slightest load like trying to move or move up a very slight slope and the KNOCKING came on strong ! I didn't do that for long ! and don't recommend any one else try it !!!!
