TractorLinks.com
Show Parts for Model:
Re: Water in the crankcase !
pbb
10-09-2013 17:33:30
I got bolts in mine. It leaked around the head of the bolt. I put some thread sealant like you put on pipe threads on the bolt threads and it stopped the leak. If that aint it your probaly looking at a crack head or block and it could be a leaky push rod tube.You could take off the valve cover and see if you have any water running down out of the push rod tubes.If its a crack in the head or block you should have some compression bubbles in the radiator when its running.Also could be a blown head gasket.
