Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Water in the crankcase !
cole in mo.
10-09-2013 17:23:40
Manifold bolts or studs would be the same if sealant was used. But if water was going into the manifold, it would smoke white, and if left sitting would fill the cyl, and wouldn't turn over. Remove the crankcase top, fill the radiator, and watch the back of the cyls.
Jim Ackerman
10-09-2013 17:51:14
 Re: Water in the crankcase ! in reply to cole in mo., 10-09-2013 17:23:40
I have seen the water draining down from between the cylinders.. it actually runs out fairly quickly. I guess I was being an optimist hoping that I could maybe just replace the studs/ have the head worked, rather than a new block.
Wendel Mi.
10-10-2013 14:36:48
 Re: Water in the crankcase ! in reply to Jim Ackerman, 10-09-2013 17:51:14
I would go with push rod tubes I've seen it take valve cover off fill it up with water and watch. Done them with head on ran a tap in them got a bolt used a steel sleeve with a bigger i.d. tighten the bolt throught the sleeve pulls them right out
