TractorLinks.com
Show Parts for Model:
Re: 1970 3020 syncro shift linkage adj.
Tx Jim
10-06-2013 06:55:08
Syncro-range is designed to only start in park or neutral.
fordtech
10-06-2013 10:11:27
 Re: 1970 3020 syncro shift linkage adj. in reply to Tx Jim, 10-06-2013 06:55:08
So how is it adj so it only starts in park and n.
Tx Jim
10-06-2013 11:47:09
 Re: 1970 3020 syncro shift linkage adj. in reply to fordtech, 10-06-2013 10:11:27
Neutral start switch is parts key #12.
Tim S
10-06-2013 10:30:10
Thar part happens on the top shaft shift cam, the safety switch is located on the right side behind the battery, tje shift cam has a tab on it that hits the safety switch button when in the nutrel position.
fordtech.
10-06-2013 13:44:17
 Re: 1970 3020 syncro shift linkage adj. in reply to Tim S, 10-06-2013 10:30:10
how do you adj linkage for no start in gear allso what is the tube with spring in it for and whitch rod does it go on.
