A Vibration
Anonymous-0
We have a '52A that has a vibration at half trotel and above. We have had this tractor for 50 years and I am sure the flywheel has nevery been off. Where should we start looking? Thanks!
If you are sure the flywheel is on correctly,check the clutch driver disc. The weight should be 180 from the flywheel weight. Ron Mn.
We did have the clutch apart over the winter. Needed to replace tbe bolts because of bad threads. Are you talking about the outer casting?
Have a friend who had basically the same problem with a John Deere B. When he solved his problem, it was the fan shaft.
The clutch end of the crank shaft and the clutch driver should both have a V stamped in them. The two V's have to line up with each other to balance the engine.
