Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Right bearing on countershaft
D-
10-05-2013 16:58:33
Leaving 3/16 movement for the bearing to work it's way in?? Won't that cause end play in the shaft??
Rick Dowe
10-05-2013 17:14:41
 Re: Right bearing on countershaft in reply to D-, 10-05-2013 16:58:33
That's what I need to know? Of course once the row of gears are installed you can adjust the end play with the shims. It's just not knowing if I should have that much of a gap. Once all the gears are in place they will push against the thrust washer which will push against the bearing too.
D-
10-05-2013 17:52:53
 Re: Right bearing on countershaft in reply to Rick Dowe, 10-05-2013 17:14:41
If you set it up with no play you still need to adjust with shims but it wont loosen later because the bearing worked it's way in.
Rick Dowe
10-05-2013 18:01:09
 Re: Right bearing on countershaft in reply to D-, 10-05-2013 17:52:53
I can push the bearing in,does the thrust washer need to be able to spin or can it be snugged up to the bearing?
D-
10-05-2013 18:20:47
 Re: Right bearing on countershaft in reply to Rick Dowe, 10-05-2013 18:01:09
It won't spin. It keeps the gear away from the bearing.
Rick Dowe
10-05-2013 18:22:19
 Re: Right bearing on countershaft in reply to D-, 10-05-2013 18:20:47
Thanks D
