PTO Air Pump Questions....
Absent Minded Farmer
I saved a pump from the scrap pile & needs a complete hose assembly & leathers replaced on the piston. The rest of it seems to be in good shape. Are there repro hoses, with the gauge & chuck already on it? Also, was the gauge marked John Deere? Is there more than one model of pump? If there is, I have no clue which one I have. I can get a pic posted later when the camera's recharged.
Thanks,
Mike
The link is to a .pdf file on the jdparts.com website. Do you have Adobe Reader on your "puter?
From time to time others have posted here about having trouble opening the .pdf"s on the DEERE site, works fine from here, I just tried it again.
The p/n for the piston leather cup is L1077C which is still available from John Deere for about $13.
There were 4 different pumps. They were driven off the pto shaft, belt pully, or flywheel.
The hose end had a screw-on chuck and a schrader valve to check air pressure. There was no built-in guage.
The 8 page Operators Manual,OM-C6-1047, includes a parts list.
