TractorLinks.com
Show Parts for Model:
Re: 52 B, starting restoration
machinery-man
10-02-2013 09:32:29
The posts I mostly see advocate brain surgery which would work but initially I wouldn't even consider going to this length. I'd take the rocker arms off till I got the engine to turn over then check the valves being free then I'd see if I could get it started...even with stuck or worn rings the tractor could be pulled for starting...30-40lbs compression will get it running and you can see what you have after that...the complete tear down may need to be done but why not try the other method first. It may be perfectly okay....
