Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 52 B, starting restoration
10-01-2013 18:44:17
Personaly I like JDfans approch. I bought a stuck '49 B, pulled the block & pressed out the pistons. I was lucky & only had to hone it & replaced the rings. Cant say that it cost a lot of money. I used the press at work, wasn't a bad push. Did the same to an R I bought sight unseen, that took a bit more & will need to be bored, but old pistons could be sold. Think if I never had the use of the press I would have tried cribbing the block in the barn & using the weight of the hay above, with an old barn jack. Just a thought, push as close to the cylinder walls as possible, they are the strongest there. Good luck. Kevin
