Pto to 1 round shaft
Anonymous-0
I have a unstyled a and a Williams pump model 40 pump 1inch keyed shaft, I wanted to use the pto to rotate the pump shaft, I'm trying to make a log splitter,is it possible? Is there a shaft conversion? What is it called,part #,where to get one?
Most sprayer pumps utilize a pto adapter from round shaft for pump to pto shaft on tractor.
A JD A will burn ALOT of gas just to run a pto pump for a splitter.
Logsplitters run way better with a small engine and a 2 stage pump. A 13HP Honda will make plenty of splitting power and speed with a 2 stage pump.
Just saying.
I think you will be turning the pump to slow at PTO speed,, be sure you calculate the performance before going on,,,the sprayer pump adapter is a good idea,,,"but" it will not handle the torque...
