1938 B rear axle hub slop
StEvEn123
New User
I have a 38 B gp with the spoked rear rims.
The hub that suppose to tighten the rim to the axle doesn't go tight enough.
I know the splines on the rim hub is warn out,but I'm not going to throw away a set of spoked rim because of that.
Is their a fix for this??
cut a tin can to fit the ring then retighten....use some never seize and you can get it off it needed...works like a charm...cut to right width, little paint never know its there....
Years ago had same problem dad took a soda can cut it into strips and slid them between hub and axle on both the high and low sides of splines never had anymore problems may also wrap the taper as well
