rollover plow for a 70
dmiller
What plowing I've done has been with a chisel on dryland (wheatland IH806, no 3pt to use a rollover with) Lately I've been coming across some opportunities on a few flood irrigated pieces.Due to the irrigated ground needing to be plowed as level as possible (so no dead furrow in the middle)plowing around here is almost always done with a 2way rollover plow. Chisel plows just can't incorporate the crop residue necessary on an irrigated piece (that's their whole point is to leave the residue).
I'm thinking of looking for a rollover plow. The only tractor I have with a 3pt is a JD 70. I'm wondering how large of a 3pt mounted rollover would work with a 70 (has a saginaw 3pt).
Two-way rollovers tend to have wide bottoms and cut deep so two bottoms will give your 70 plenty of load. Where I grew up in SE Colorado a 4020 was considered a three plow tractor for this reason.
You'd probably be happy with an 825 3pt roll-over plow. They made an 820 series also, but it wasn't built very heavy.
