TractorLinks.com
Show Parts for Model:
Re: 55 plow
Tyler-MO
09-23-2013 07:25:05
These wheels use sleeve type bearings. Depending on if you have clutch lift or hydraulic lift the wheels will be the same or different.
They are adjusted by using shim washers on both side of the wheel sleeve. Unless they're broken, the wheel sleeves can usually be adjusted. Keep in mind that an inch of side play at the outer wheel tread is acceptable for a used plow. Even when new, these sleeve type wheels weren't free from wobble or play like we are used to with precision type tapered roller bearings.
New wheel shims for the 55 plows aren't available, but I probably have some used ones. If you dissassemble your wheel and find broken parts, let me know as I have plenty spares for parts.
573 768 4O92
Tyler in IL
luv2wrench
09-23-2013 08:50:00
 Re: 55 plow in reply to Tyler-MO, 09-23-2013 07:25:05
thank you for your knowledge about this plow. its very helpful.
