2510 hydraulic filter canister bolt question
After putting finishing up load shaft bushing/seal/shim, before putting in new hydraulic fluid decided to change both hydraulic filters. Noticed that the BACK hydraulic filter, did not have a spring or snap ring on the center bolt (inside canister). FRONT hydraulic filter did.
QUESTION: Is the back hydraulic filter supposed to have the spring and snap ring?
Any guidance would be appreciated. Thanks Again!
