warm up powertrol
Anonymous-0
How can I help to warm up the oil in the powertrol of a 720 and 830 (to change oil)? Can I loop a hose from one hydraulic coupler to the other & hold/tie hand lever in operating position for a while?
Thank you
That is wear the PRESSURE or check valve is tested, using a shut off and Gage assey so i guess you would. But may be DIFFERENT than the CUSTOM POWER TROL procedure Testing and oil warm up??????
