1951 JD A Radiator question-followup, radiator sealant
I still had a small stubborn leak between the the lower water pipe that fastens to the cylinder head. I decided to add Bar's Leaks to stop it which it did. The cooling system holds 8 & 3/4 gallons. Thinking it held more I put in 3, 11 oz bottles of Bar's Leaks where 2 would have sufficed. Will I be okay with the extra sealer mixed with the anti-freeze? Should I drain some of the coolant out and add additional coolant? I use a 50/50 premix of anti-freeze.
Thanks for all your assistance.
Was that BARS LEAK compatible with ANTI, as now days most specify add to plain water for sealing and after add ANTI. In other words not compatible with anti.
