Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Changing a 350 mower sickle cutter bar. Any tips or tricks?
Randy G
09-16-2013 18:17:37
Got it replaced. Replaced all the wear plates too. Thanks for all the great advice!! Problem now is the mower will not raise enough to keep the flywheel out of the dirt.(behind the wobble box that the belt drives the cutter)I adjusted the float spring according to the manual. Bar moves freely. Its on a 530 WF. What am I missing?
James Howell
09-16-2013 19:13:00
 Re: Changing a 350 mower sickle cutter bar. Any tips or tricks? in reply to Randy G, 09-16-2013 18:17:37
Lower the mower to the ground.
Raise the lift arm links on both sides to raise the back of the mower frame approximately 12" off the ground.
This should give enough room to slide your fingers under the subsole.
The subsole should "float" over the ground when adjusted properly.
When you raise the mower frame, it should be about 18" off the ground.
The bottom of the cutter bar should be about 10" from the ground.
The end of the cutter bar should be about 41" from the ground.
These settings should keep the flywheel out of the dirt.
Hope this helps.
