TractorLinks.com
Show Parts for Model:
730 diesel no start
Mece
09-16-2013 15:38:42
ok I'm still working on the old tractor trying to get it to go. I changed the fuel filters and now I can't get it started. Before I changed the fuel filters I could get it to start but would only run at wide open throttle for short period of time. So I guess my question is do I not have all the air out or should I be trying something else? Is there a way to check the fuel transfer pump? I pull it around for about 200 yards and it'll smoke for the first 100 but not start and when I stop pulling it it seems like there is a little air in the fuel filters again. So I took the transfer pump off and the gov. shaft on it turns so I took the plate off the transfer/lift pump and I don't know how tight the gears in there are suppose to run but they seem loose to me. Are there any specs for the pump if the engine isn't running? and is there any rebuld kits out there for them? Also my book says something about a third bleeder and I can't find but the two on the filters so where is the other one or is it possible for it not to have it? sorry if i'm a little scatter brained writing this and I hope this makes sense, I've fried my mind thinking on it.
Thanks
john cummins
09-17-2013 17:06:55
 Re: 730 diesel no start in reply to Mece, 09-16-2013 15:38:42
Deere should have one as I just got one a year ago and if not I have an extra later John
Mece
09-16-2013 18:14:20
I just pulled off the injector pump inspection cover and found the rack return spring broke. does anyone know where to get one does jd still have them?
mbdeere
09-17-2013 19:13:26
 Re: 730 diesel no start in reply to Mece, 09-16-2013 18:14:20
The third bleeder is on the left side of the tractor on the governor control. Use a 9/16 wrench
