On the 3010 I am working on I did maintenance on the air cleaner assembly as shown above. I cleaned out the cup (#16) and put fresh oil in it. I must of had a half inch of gunk in the bottom.
I also removed and cleaned the intake assembly (#8) at the top of he air cleaner canister. It as really coated with oily dust. After running the tractor I noticed some oil up around that intake assembly. I know I put the oil to the correct level in the cup. Is there maintenance I need to do on the canister between the cup and the intake assembly? Since both were coated with oil dust/gunk I am wondering if the same is true for the inside of the canister.
Thanks. Paul
Thanks. Paul
