Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 3010 Generator Update
John T
09-16-2013 05:28:32
Thanks for feedback, many on here arent very good hands at doing that. If it charges 16 amps if you dead grounded the Gennys FLD post (says the genny itself is okay) but NOT otherwise, the problem is most likely the VR isnt well grounded (did you insure that) or is bad (maybe field control relay contacts are burned???) or the wires bad from FLD on genny to FLD on VR
PS that Motor Test involves voltage on ARM (case frame grounded) first with FLD grounded (spins) then when FLD is ungrounded (spins faster), not sure what you did??
Best wishes, thanks again
John T
09-16-2013 05:37:19
 Re: 3010 Generator Update in reply to John T, 09-16-2013 05:28:32
Thanks for the response John T.
We checked grounds and wiring several times so I am pretty confident in that.
Yes, we got two speeds when doing the motoring test.
On the second go around we followed your procedure exactly. It worked well. When we got the 16 amps of charging we were off plan but that was after we went through your test procedure. We wanted to ensure the Generator could send a charge.
I will order a VR and let you know the results.
