Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
H Gearshift Knob Removal
JD GIMPL
09-15-2013 19:24:41
Hi Guys
What is the best way to remove the knob off the gearshift without chewing up the shaft.
Thanks Gimpl
JDBert
09-17-2013 17:05:04
 Re: H Gearshift Knob Removal in reply to JD GIMPL, 09-15-2013 19:24:41
I've used a vise grip on the lever and a craftsman strap wrench on the knob with good results. To this day-- its the only thing I've found the strap wrench to be good for!!
rbooker
09-16-2013 19:42:34
Could try an oil filter wrench to hold the shaft or use some vise grips and some leather under them to protect the paint.
dan_41jdh
09-16-2013 18:42:34
The F292R ball is screwed onto a 7/16" coarse-thread end of the shift lever. There really isn"t any way to effectively grip the shift lever as there are no wrench flats, cross pins, or other means to prevent the shift lever from rotating as the ball is screwed off.
However, the threads are normally not too badly rusted as any water tends to run down the shaft instead of up into the threaded area.
The best I can suggest is to clamp a good, sharp-toothed vice grip onto the shaft and try not to let it slip. Even if some teeth marks are left on the shaft, it wouldn't be too hard to file those flat and fill any remaining grooves with body filler to hide any modest damage.
Richard G.
09-16-2013 18:05:17
There is no knob on my H gearshift.
Show us a photo.
Richard
