I got a 1530 JD that the Hydroulics quit working on after it runs
for awhile. I cleaned the transmission screen and replaced the
filter a long with changing the fluid. I got to checking and the
Hydroulics work as long as the resavor if full but after working
the lift several times or the loader it drains it. Does that
indicate a bad transmission pump? Or how do you tell if its
bad? I have a manual and it says to use a flow meater to
check it but I don't have one or can I find one close. Is there
any other way to check it without the gauge? I have a pressure
gauge if I can use it to check the pump. Thanks for any help or
advice !!
advice !!
