Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: What year John Deere A?
LucasBrackins
09-02-2013 08:41:32
That part number lists for a JD60? I trust you.how does it attach? should probably start a new thread when I get closer to the swap
bigboreG
09-02-2013 15:54:07
 Re: What year John Deere A? in reply to LucasBrackins, 09-02-2013 08:41:32
Yes it indeed does, but thats because the 60 used the same flywheel. Now when attaching the correct flywheel, if you do indeed have the right crank thats supposed to be in there, you will see the splines on the crank as well as threads. Slide the flywheel on, but make sure you have the timing marks lined up before hand and the pin in line with the oil slinger. . .you might have to use a dead blow hammer to get it on. Run it in until the pin engages with the slinger, then use the big metal nut to set the endplay. Will possibly need a block of wood against the clutch to keep it from moving out and giving you a false setting. Then tighten the bolts on the flywheel, but dont use a big bar use a torque wrench and set them at the values specified in the Service manual or I&T book. When your done, take a punch and bend out the tabs on the metal nut to set it in place.
