Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4020 questions
T in NE
09-01-2013 23:18:22
I put a couple gallons in the radiator that day. I'd say it pushed a gallon back out.
I don't know how long it's been since much of anything was done with this tractor. It runs a couple hours a day when we are using it a lot. The engine oil hasn't been changed in 3 years, but it probably doesn't have 100 hours on it in that time. Boss traded an old bale processor for it.
David G
09-02-2013 11:33:07
 Re: 4020 questions in reply to T in NE, 09-01-2013 23:18:22
The level should maintain about an inch or two above the cores, if it does, then do not worry. I would expect the front pump is worn out and maybe the trans pump too.
Make sure and check filter and screen as someone recommended.
Tim S and TX Jim are the experts on these.
Tx Jim
09-02-2013 11:56:06
 Re: 4020 questions in reply to David G, 09-02-2013 11:33:07
David
Thanks for the compliment but Tim's JD knowledge is waaay ahead of mine.
Jim
T in NE
09-02-2013 18:27:20
 Re: 4020 questions in reply to Tx Jim, 09-02-2013 11:56:06
I forgot to mention, the valve for the loader bucket has some by-pass in neutral, but holding the lever to where it quits doesn't seem to smooth out the loader any.
We run a wire winder on the remotes, and it runs smooth, but the hoses on the post-hole digger can jump around a bit too.
Copyright © 1997-2015 Yesterday's Tractor Co.
