Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: What year John Deere A?
bigboreG
09-01-2013 10:14:52
Looks to be above 584000 SN. With parts from earlier tractors added here and there. You should be able to put electric start flywheel on without any problems. I did vice versa on an earlier A that was hand crank and worked out fine. You will need the later A flywheel though that takes the big tin nut, cant tell in pics but hopefully it dont have an earlier crank without the threaded end. If it does, then you wont be changing just the flywheel. Unless you use older A flywheel with ring gear but i dont know if that will work with your starter on the bottom, because those earlier As had the starter on the top. But that wont work in your situation. If you need help i can walk you thru what your gonna need.
Copyright © 1997-2015 Yesterday's Tractor Co.
