Jerry Frank
New User
I have a John deere 3032e. When i raise the 3 point hitch with
the shredder attached it starts it starts bouncing up and down.
The loader works fine and fluids are full. Does anyone know
what might be causing this
I'm not very knowledgeable on the newer tractor hyd's but do understand general hyd's. 1st what is the size/weight of the shredder? it's possible the control valve isn't returning to neutral. It's also possible the control valve or lift piston is leaking causing the 3 pt to drop a very little and then require raising again also known as hiccuping.
