carterbeauford
picked up a nice original 620 over the weekend, I intend to restore it to work full time on my hobby farm. I'll have a bunch more questions as I tear into it, but for now:
1) if the sediment bowl is not shut off, it gets gas in the oil. it runs rich and smokes. the automatic fuel shutoff has been eliminated, its just a sediment bowl with a line to the carb. the previous owner said it's the needle valve. can I replace this myself? worth sending the carb to Roberts?
2) the 3 point works but drops if I let it sit, I assume the problem is in the ram, how hard is this to fix?
3) it has mismatched oversized tires on it. I read the original size is 12.4-38 which sounds small. I'll be adding flat top fenders, will 12.4-38s leave too much of a gap between the fender and top of tire?
