Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 4020 Synro Shift Clutch will not release
David G
08-22-2013 15:17:47
It also sounds like neutral switch is not working.
10-06-2013 12:27:00
 Re: 4020 Synro Shift Clutch will not release in reply to David G, 08-22-2013 15:17:47
If you have some reliable help with another tractor, drag it out where you can pull it, put it into 6th or 7th gear and pull it with the clutch pedal held down, engine off. I use an old tire between two chains as a shock absorber and repeatedly jerk it a bit. My 3010 had the same problem and that is what worked for me. When the engine fan stops turning the clutch is free. Since my tractor often sits for extended periods, I block the clutch pedal where it is just released and have had no further problems.
