Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Knock
Paul from MI
08-20-2013 20:41:17
Correct crank end play is .005-.010", which is adjusted by sliding the flywheel on the crank. You will have to push the crank to the left to slide the flywheel far enough in to get the right end play. I remove the clutch cover and use a hydraulic jack to do this. If your flywheel was out far enough to miss the starter drive it had to be about 1/2" too far out---way, way tooo much! The crankshaft spacer slot without doubt would be out of line with the flywheel drive key, so that would prevent the flywheel from sliding to its correct position. If you are getting a knock after moving the flywheel you may not have it tight on the splines, or if run that way very long the splines on the crank or flywheel may be worn beyond use. There are people who rebuild cranks, but it's not cheap. Good luck with it.
