TractorLinks.com
Show Parts for Model:
Re: 620 leaking oil flywheel
jturbo10
08-14-2013 09:22:53
I doubt it but it might. I have a JD 630 that I'm just finishing up installing a new slinger seal. Was a simple job except for removing the flywheel. Previous owner had buggered up the lock nut threads at the end of the crankshaft so there isn't any lock nut to set the end play. The splines were also very rusty and filled with paint and grit so it took a lot of effort to get it off. I built a puller to finally get it off the crankshaft. Cleaned up all the splines and grooves and it went back on very easily. The oil slinger has a slot that must be aligned with a square pin on the flywheel. Make sure to check that the flywheel and crankshaft V markings are lined up. I also used a finishing punch to mark the correct alignment. You will need to move the slinger groove to accept the pin on the flywheel. The slinger seal is a square (round) seal I bought from Mother Deere. My outer thrust bearing/gasket was torn so I had to replace it. When you put the housing that covers the slinger back on be sure to use shims to get it perfectly aligned/centered with the crankshaft. My ITT manual is very good describing the process and settings. Had to loosen up my starter to get the flywheel off. Bought new grade 8 bolts and nuts, fine thread to be safe. Torque figures were around 285 ft pound but I have a 600ft lbs manual torque wrench so that was not a problem. Some people use a multiplier or a 3/4 or 1 in socket and a three ft cheaper bar to approximate the torque. Be sure to check it again after you run the tractor for a few hours. That flywheel is heavy so use a engine hoist with a nylon axle loop to remove and replace the flywheel. Not easy but I did it without any help. Have fun.
