Rich'sToys
- Location
- Southern MN
I'm replacing the water pump on my 50 LP. The replacement pump (from Steiners) has a port for the bypass tube. My tractor does not have the bypass tube and the pump came with a plug for that hole.
My question is this. The hole has an O ring in it, and it looks like that plug just pushes into the hole. Is that really all I have to do, and it won't leak? There are no threads or anything.
Also, the plug is square on one end, but on the other end it narrows down and has a series of ridges or tiny splines on it. If all I have to do is stick this in the hole, which end goes in first?
This is my first encounter with one of these. Thanks for the help!
