TractorLinks.com
Show Parts for Model:
Re: 70 clutch issue
JOHN DEERE 70
08-13-2013 14:35:14
usually the splines get warn between the clutch driver and the crank if not kept tight .Was the bolt bottoming out.I f I remember right there should be 1/4 " difference with the clutch driver sticking out past crank.
gary in neb.
08-14-2013 05:44:49
 Re: 70 clutch issue in reply to JOHN DEERE 70, 08-13-2013 14:35:14
the bolt was not bottoming it would tighten up ok. just moved the drum so far that i was concerned as my 60 dont do that and neither does a friend of mine's 70. i put a washer spacer between the to take up the slack but wondered if that was why i was having some of my clutch issue that it went out of adjustment so fast.
JOHN DEERE 70
08-14-2013 09:32:05
 Re: 70 clutch issue in reply to gary in neb., 08-14-2013 05:44:49
did your clutch driver pull off easy,when you took It apart?
gary in neb.
08-14-2013 09:34:30
 Re: 70 clutch issue in reply to JOHN DEERE 70, 08-14-2013 09:32:05
yes it did, seemed very loose to me so plan on getting a new one. figured that was the reason the bolt was not tightening it all up.
JOHN DEERE 70
08-14-2013 09:49:11
 Re: 70 clutch issue in reply to gary in neb., 08-14-2013 09:34:30
becareful the splines don't wear on the crank if the driver is still slopy on crank.
