7520 U joints
I need to replace the u joints on my 7520, the top drive shaft in the center of the tractor. I looked on the jd parts website and it lists different numbers for the u joints. I"m wondering if anybody can give me the number to the right one. The numbers are the RE40111 and the other is AT74268. Thanks!
AT74268, plus 4 AT59126 bolts (if needed) APPEARS to be the correct cross kit for the UPPER driveshaft connecting the clutch output to the transmission input.
RE40111 APPEARS to be the cross kit for the LOWER driveshaft that powers the front axle.
