Hey guys, I"m working on a 430s #156638 five speed tans no live power. The guy said it made a lot of noise in third and fifth gears. I did hear the noise I"m pretty sure in fourth as well. It is a very loud growling - howling noise, I split the tractor at the transmission, (under the dash) but nothing really pops out at me to be worn or damaged, the input shaft bearing in the front of the case seems worn, but this since it only makes noise in the higher gears I"m not sure. The pinion shaft seems to have a little end play as well as up and down play. Anything specific on these tractors to look for?
