Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Shutting down Model H and Carb/fuel question
John T
08-13-2013 05:38:58
I advise you to turn it off by shutting off the gas and letting her starve out and die and then open the throttle wide open and leave it set there afterwards. On my hand starters Ive done it that way for yearssssssss and its proven to be the best for easy hand starts. Id have to look it up, but I believe thats how mother Deere advised it be done back in the day.
As you say, others may have different methods and opinions, all I can say THATS WORKED BEST FOR ME, so its your tractor and your choice so go for it however you wish.
PS for the old al fuelers that used lower octane Tractor or Drip Fuel etc., it was good for the gasoline to flush the carb (shutdown) and then, of course, let it re fill with gas for start up prior to warm up then switching to tractor fuel..........
John T
JD Gimpl
08-13-2013 12:09:34
 Re: Shutting down Model H and Carb/fuel question in reply to John T, 08-13-2013 05:38:58
Hi John T
Why do you leave the throttle wide open after it stops?
Thank you
Gimpl
John T
08-13-2013 12:57:55
 Re: Shutting down Model H and Carb/fuel question in reply to JD Gimpl, 08-13-2013 12:09:34
Its my opinion that with the throttle plate sittin there wide open that allows more air to freely circulate in the cylinder combustion area (any left over vapors to evaporate versus raw gas left that washes oil off the walls n rings) so all is purged out and youre ready to take in a fresh well vaporized fuel air mixture on the restart. Sound best to me and "seemed" to help but I have no scientifc evidence or data whatsoever......
John T
nlastovi
08-13-2013 17:27:13
 Re: Shutting down Model H and Carb/fuel question in reply to John T, 08-13-2013 12:57:55
But wouldn't that only be possible if the intake valve was open on a cylinder? I'd suspect that only one of them might be open at a time. Even then, only one of them might even be open at all. Or did I miss the point entirely?
John T
08-13-2013 18:41:13
 Re: Shutting down Model H and Carb/fuel question in reply to nlastovi, 08-13-2013 17:27:13
I sure agree and admit there would be MORE/BETTER circulation if a valve(s) were open, but regardless it seems that the carb butterfly being left open would contribute to better evaporation????
Hey Im NOT a chemist or fuel expert, just going on what SEEMS a better way to leave the carb (throttle plate open) when they are sitting IM OPEN TO HELP HERE !!!!
John T
JD Gimpl
08-13-2013 14:30:43
Thank you John T.
I truly appreciate your knowledge and the fact that you would pass it on.
Have a great day
Gimpl
John T
08-13-2013 16:40:51
 Re: Shutting down Model H and Carb/fuel question in reply to JD Gimpl, 08-13-2013 14:30:43
Youre welcome, I'm fairly handy on electrical stuff but that carb and venting above is sorta out of my area but still my honest "opinion" (its worked for me at least)
best wishes
John T
