TractorLinks.com
Show Parts for Model:
Re: question on starting 60
markjd60
07-31-2013 18:22:43
iv had my 60 since 2008 never had much issues starting it, its started every winter and has fed 100 round bales a year, what I have did with it was re wired it has a new jd switch new points and conds a 12v resistor coil, I run my charged white wire off the middle post on the voltage regulator it charges at ten amps till full charged, I have only put new plugs in it once, only issue im running into now is carb trouble, cause they had a rigged up chock lever on the carb , but I got a rebuilt carb to try on it don't have the right chock rod to at the time
markjd60
07-31-2013 18:28:14
 Re: question on starting 60 in reply to markjd60, 07-31-2013 18:22:43
middle post on regulator makes it charge good its called winter charging post, with the lights on im still pushing 3 amps in to it lights off 10 amps
till full charged
markjd60
07-31-2013 18:31:46
 Re: question on starting 60 in reply to markjd60, 07-31-2013 18:28:14
choke rod*
markjd60
07-31-2013 19:02:01
 Re: question on starting 60 in reply to markjd60, 07-31-2013 18:31:46
I set a big round bale every 3 days in winter to cut waste I live in ohio never had my tractor not started since 2008
markjd60
07-31-2013 19:05:20
 Re: question on starting 60 in reply to markjd60, 07-31-2013 19:02:01
small rounds bales make it a day, if I fill up the field with them they weste half of them they get wet inside
