TractorLinks.com
Show Parts for Model:
Re: 4430 hitch lowers when you use remotes ?
donmyeil
07-29-2013 06:03:13
one or both valves are leaking . Start tractor cold and feel the valves to see which one heats up first . I think the rockshaft valve isn"t adjusted right causing the problem .
jd720
07-29-2013 14:50:25
 Re: 4430 hitch lowers when you use remotes ? in reply to donmyeil, 07-29-2013 06:03:13
Are you talking about the linkage to the rockshaft valve ? If so what is the proper procedure for adjusting it ? It may be the linkage is adjusted wrong because I shortened it by about 1/2 inch before the control valve was rebuilt just so it would go high enough to lift a bale off the ground.
donmyeil
07-30-2013 07:23:25
 Re: 4430 hitch lowers when you use remotes ? in reply to jd720, 07-29-2013 14:50:25
That"s most likely your problem. There is a procedure in the teck. manual to adjust the valves and linkages IN THE PROPER ORDER .This includes the negative stop adjustment .
Tim S
07-30-2013 07:35:01
 Re: 4430 hitch lowers when you use remotes ? in reply to donmyeil, 07-30-2013 07:23:25
Yes as Don stated you need to follow all the steps in order. The free travel in your 3pt lever is probably a bit tight along with leakage in the SCV's causing a premature pressure drop,,and also a leaking cylinder packing in one of the loader cylinders could also add to the problem,,as we have said many times the SCV's are not a good way to run the loader...
Tx Jim
07-29-2013 16:47:37
Adjusting the L/D mechanism has several steps outlined in the JD service manual.
