A3404R Weights Question
Bobl1958
I have a set of A3404R rear weights that I was going to pug on my 620 standard with 30" rear wheels. It appears these are for larger wheels. Does anyond know the correct rear weight part number? Thanks in advance - Bob
F1592R will fit your standard as they are smaller in diameter and were made for 26 and 30 inch centers. However they will "not" fit a heavy duty 34" or 38" cast center like on a 3020 or 4020. I found that out the other day as I tried to install a set that I have and the little rasied bars on the outside of the center of the hub interfere with the weight.
Bob,
I think I have those weights on my 60 std with 30 inch wheels. I know they are a different number than my 70 std. I will try to post a pic when I can.
Bob,
These are the A3404R with the oval hole. Mike Alyward (sp) has a good explanation that there are 3 versions of this rear wheel weight all with same number.
<a href="http://s614.photobucket.com/user/DaninOhio/media/photo-819.jpg.html" target="_blank">
photo-819.jpg" border="0" alt=" photo photo-819.jpg"
</a>
Sorry I do not have them all painted up yet.
(quoted from post at 18:11:54 07/28/13) I have a set of A3404R rear weights that I was going to pug on my 620 standard with 30" rear wheels. It appears these are for larger wheels. Does anyond know the correct rear weight part number? Thanks in advance - Bob
I also have a 730 with 30 inch wheels and it takes a R61727 weight on the first one. They call this a starter weight and the regular A3404 weight will not go on. Glad to help you. Those starter weights are scarce.
