Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: brake problems on 1530 jd tractor
Tim S
07-28-2013 06:49:27
That sounds like the equalizer valve, under plug #14,, remove the ball and spring (1 for each brake,left/right) clean the area the give spring #12 a bit of a "stretch' to give it more tension and put it back together,, you may need to add more fluid in the top of the valve,under the floor board, or let it run a bit, to let it refill naturally, this is slow, and steady, then re-bleed the brakes, and see what happens..
