Back on my 60C Hydraulic system
tim s
Getting the Hydraulic system completed, it got put on the back burner,,got to get her ready for the Rantual show,,here are some more build pics...
Thanks,, It's been a Fun Project,, I'm setting it up for a 6-way dozor blade the front lever is a wobble stick for up-down & float- left/right tilt, the 2 stick valve will be for blade angle, and the rear stick will be for the remote coupler. I still don't have a blade for her yet, I'm thinking a 6-way off a 450 or 550 will be right, I will not have a blade on it for Rantual, my original thought was to portray an Ag Crawler in Design, with the Live PTO, and Ag draw bar set-up,,and now the remote valve to pull my 30 combine and 555 plow.
The 2 spool valve looks likes A Greesen (Now Parker) SP valve. If it is why is the plug in the normal return passage? You didn't add a closed center system did you?
No, it's an open system, I'm just mocking things up for the placement right now..then the plumbing...
