hydrolic leak 2840 john deer
Anonymous-0
my 2840 started spraying hydrolic out of a small hole below the steering wheel can you tell me what the promlem is it started when i hit a stump and turned the wheels all the way to the left
I would think you blew a seal inside steering valve when stump was encountered. Valve will need a overhaul kit installed. Parts states to order the adjuster(parts key #9) along with the seal(parts key #7)
6ea-L34451 O-Ring ADD 1.19 USD 7.14 USD
1ea-T22260 Seal ADD 9.27 USD 9.27 USD
1ea-AT19858 Adjuster ADD 130.96 USD
