TractorLinks.com
Show Parts for Model:
Re: JD 1209 Mower Knife Drive Arm
hayfarmer
07-23-2013 08:14:04
I also have an older 1209. A couple years ago I needed a new sickle and sicklehead. The only way the unit came was the newer style and you had to change pitman arm and all. I could still get the old style sickle head and the bare sickle bar(no sections)so I did that as I didn't want to spend big bucks to update. I don't see why it would cause a problem though. Does the pitman arm adjust up and down where it hooks to wobble box like on old style? The 2 bolts that hold pitman arm have to be kept really tight(torqued)
philsmith
07-23-2013 08:31:41
 Re: JD 1209 Mower Knife Drive Arm in reply to hayfarmer, 07-23-2013 08:14:04
Thanks for the quick reply. The new pitman arm attaches to the yoke with a single nut - I think its the same for both styles of Pitman arms. It looks as though its possible to set the height based on how tight the nut is. Which two bolts are you referring to on the pitman arm?
Roger in Iowa
07-23-2013 19:40:46
 Re: JD 1209 Mower Knife Drive Arm in reply to philsmith, 07-23-2013 08:31:41
Height is not set by how tight the nut is. It has to be TIGHT, but I do not know the torque!
Tx Jim
07-23-2013 09:11:38
This is the old style knife drive arm that hayfarmer referred to. IS the knife drive TIGHT on the wobblebox shaft?? Also does the knife drive pin fit tight in wobblebox drive arm?
