TractorLinks.com
Show Parts for Model:
Re: 420 won't start
JD Gimpl
07-23-2013 08:13:18
The battery is a 6 volt that is 2 years old. I had replaced the cables then as well. It is a positive ground system.
The coil is original from when I bought the tractor 12 years ago. How do I check ohm's?
Thank Gimpl
buickanddeere
07-23-2013 14:33:06
 Re: 420 won't start in reply to JD Gimpl, 07-23-2013 08:13:18
What is the CCA rating of the battery?
What size of cables?
Where is the chassis return/ground bolted to? Coil's + should be connected to the distributed and through to the points. Using an ohm meter. A six volt coil will measure approx 1.5 to 2.0 ohms across the primary terminals. A 12V coil will measure approx 3.0 to 4.0ohms.
JD Gimpl
07-24-2013 18:09:07
 Re: 420 won't start in reply to buickanddeere, 07-23-2013 14:33:06
Hi buickandeere
I got the 420 started by towing it and bump starting it. It runs anywere from 2 minutes to 5 minutes fine and then starts missing or choking out like it is running out of gas. I pulled the plug on the bottom of the carb and fuel pours out of it fine. If I am quick with the choke I can keep it running most of the time.
This tractor has run flawlessly for the past 8 years so I am puzzled. Seems like it could be electrical or fuel.
I took the carb apart twice and it looked perfect inside so I am really wondering where to start.
Any advice would be appreciated.
Gimpl
